flywheel/clutch combination
Old Sep 20, 2012 | 06:06 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default flywheel/clutch combination
anyone has a suggestion for a flywheel/clutch for a 1991 CRX SI? stock engine, turbocharged. seems the choices have dwindled since i had to shop for one.
driveability is important.
Old Sep 20, 2012 | 07:58 PM
whited's Avatar
CRX God
Default Re: flywheel/clutch combination
Lightened Chromoly Flywheel (ACT) and Centerforce Dual Friction.
You could honestly just go with a OEM style flywheel, but if your going to get something nice Chromoly is more reliable than AL.
The only thing I don't like is that Centerforce doesn't have their centrifugal weights on any honda clutch I have seen yet (B and D).
Old Sep 21, 2012 | 03:10 AM
Creator's Avatar
I second clutch advice.
Old Sep 21, 2012 | 05:27 AM
v4lu3s's Avatar
RTFM
Competition Clutch all the way. My buddy uses a pucked competition clutch on his 300 whp daily driven ep3. I have used them on D and H series as well, they have fairly light pedal pressure, but can hold very well if you get the right one for your torque output. they are also in general cheaper than others, they do not powder coat their pressure plates as they feel that is a waste of money on a part you do not see.
Old Sep 21, 2012 | 10:54 AM
Charlie Moua's Avatar
yes Comp FW with Comp stg4 would be ideal..... not very stiff either.
Old Sep 21, 2012 | 12:04 PM
whited's Avatar
CRX God
Originally Posted by v4lu3s
My buddy uses a pucked competition clutch....
I would not recommend a puck clutch for a daily driver. What I like about the CenterForce is it is really a hybrid between a puck and a disk.
Old Sep 21, 2012 | 12:17 PM
good, i already have ACT flywheel (do not remember if streetlite or prolite) and hyper pressureplate with OEM disc and experience pretty bad chatter in first gear.
with centerforce i hope that will stop. i'll resurface the flywheel as well.
Old Sep 22, 2012 | 06:56 AM
tonylovesjdmEF9's Avatar
go with exedy stage1 and that act flywheel you should be fine friend of mine had a ef crx boosted with stage 1 exedy and stock fly wheel drove nicely no slipping from the clutch and the pedal feel was nearly as stock also didnt snaped the clutch cable
leondx
Apr 5, 2010 06:19 AM
EJ8 GSR-T
Feb 15, 2006 07:50 PM
allstockb18c
Jul 3, 2005 12:44 PM
Mr Samson
Nov 4, 2002 10:57 AM
