Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Question about damage in engine Pilot 06
Old Sep 20, 2012 | 11:39 AM
carlosdlovera's Avatar
Default Question about damage in engine Pilot 06
Hi i introduce myself, im Carlos from Venezuela
the reason of this topic is that i need an advice from you..
recently my Pilot 06 had some problem with the oil, having one big issue with the proper function of the oil pump, well the damage have been a pain in the %/&...my mechanic says that the main bearings from the crankshaft has slided with no oil so it damaged the main caps and part of the block, he gave me two solutions, the first one is to do a bore work (im not sure about the name in english) but he cant give me warranty for this job, and the other one is to buy another block mainly because the main caps was eaten by the bearings and they dont have a part number by themselves..what do you all think that i should do?
my other question is this: i have two part numbers from the block, 11000-PVK-A00 and 11000-RJE-A01, these two says emission: KA - US Market Spec but one says its from usa and another from canada, and the canada one is cheaper by 300$ aprox. which one should i buy? and the canadian should work for my pilot? 300$ for me in my country is a lot of money and i think that these block are the same. am i right?
Thanks in advance...
Old Sep 21, 2012 | 12:19 PM
Default Re: Question about damage in engine Pilot 06
can someone help me please?
Old Nov 18, 2012 | 11:04 AM
goneb4u's Avatar
get on the net and buy a short block assembly from a dealer, around $2000 US, will be your best bet.
Old Nov 28, 2012 | 11:57 AM
Deererainman's Avatar
Not sure, but I bet the Corporate Honda website has someone that may know.
http://www.honda.com/
Old Dec 5, 2012 | 08:36 AM
albertodsa's Avatar
Carlos, lo mas sencillo que peudes hacer es comprar otro motor.
en ccs hay una venta de motores que se llama Yako. ahi compre el motor para hacer un swap a mi integra (b20) y todo perfecto!
mikemjohnson
Apr 13, 2008 12:54 PM
vtec_bangeR
Jan 21, 2007 07:56 AM
dr_latino999
Nov 22, 2006 07:46 AM
7rrivera7
Jun 23, 2006 12:14 PM
civickiller
Aug 7, 2004 03:00 PM
