89 civic CEL code 16
Old Sep 19, 2012 | 03:45 AM
BIGef's Avatar
Default 89 civic CEL code 16
well got my car running but when it start it idles like crap.
got a code 16 which is fuel injector.
and sounds like my car is running on 3 cylinders.
did a compression test and its 180 across the cylinder.
spark plugs are all black!
car has a b18 swap coverted to obd1!
smells like alot of gas from the exhaust like its running really rich
checked ohms for my injectors and was getting 2.6 ohms on all injectors. seems pretty low for an obd1.
any help appreciated
Old Sep 19, 2012 | 04:37 AM
dephtone's Avatar
Default Re: 89 civic CEL code 16
I would start your troubleshooting by looking at this page from the factory service manual.
http://www.justanswer.com/uploads/hy...ic_code_16.pdf
Hope this helps!
Old Sep 19, 2012 | 04:48 AM
v4lu3s's Avatar
RTFM
2.6 ohms...i am assuming you still have the resistor pack in there?
Old Sep 19, 2012 | 04:58 AM
Former User's Avatar
-Measure resistance across the terminals of each injector.
-Test whether all 4 injector clips get battery voltage. If so, test whether the voltage reaches the 4 ECU pins.
Old Sep 19, 2012 | 10:10 AM
BIGef's Avatar
Hope this helps!
thanks for the help
no resistor pack. this is a obd1 converted. just got the car. i dont think this would be obd0 injectprs. thi harness is for obd1. would obd1 injector clips fit on obd0 injectors?
tested the resistance and im getting 2.5-2.6
on the injector clips i test it on both pins? wgat voltage should i be getting?
Old Sep 19, 2012 | 10:28 AM
What injectors do you have? The stock B18 injectors should have 10-13 Ohms.
One of the two terminals in the unplugged injector clip should have battery voltage (~12.5V) to body ground.
Old Sep 19, 2012 | 05:10 PM
BIGef's Avatar
im not too sure what injectors i have. i just got the car. and its reading 2.6
ill check if im getting voltage and ill get back to you
Old Sep 20, 2012 | 12:32 AM
BIGef's Avatar
rechecked my resistNce on the injectors there all getting 2.6
i did what helms manual said check if injectos are clicking.
there all clicking good.
found out #3 injector is leaking.
will the leaking trigger the CEL?
Old Sep 20, 2012 | 05:15 PM
v4lu3s's Avatar
RTFM
2.6 ohm injectors should have a resistor pack. hondas and acuras need 10-13 ohms to function properly so they do that by the injector having the correct ohms or the injector plus the resistor pack. get the right injectors or get the resistor pack in there.
leaks will not trigger the code, unless the injector is so broken that it will not function electrically.
Old Sep 20, 2012 | 09:19 PM
BIGef's Avatar
im guessing that the car is running like crap cause of the injectors?
i cant seem to fine the plug for the resistor box im just gonna get myself obd1 injectors.
why am i getting code 16 then? could not running the resistor box trigger the code?
Old Sep 21, 2012 | 05:27 AM
Code 16 is a fuel injector circuit problem. The incorrect injector resistance is throwing the code.
Old Sep 21, 2012 | 05:54 AM
BIGef's Avatar
thanks RonJ@HT for the reply.
ordered my self the correct injectors. will update as soon as i get them.
the car starts and all but idles at 100 pretty damn low.
when i rev it to 2-3k rpm drops and dies.
Old Sep 22, 2012 | 10:14 PM
BIGef's Avatar
Couple of vids how my car is idling on low imp. injectors. With no resistor box on obd1 swap b18. Not sure if the injectors are causing it to idle like this. Still waiting for my obd1 injectors
Don't worry CEL is for code 16-fuel injector and code 41-o2 sensor
Old Sep 27, 2012 | 07:30 AM
BIGef's Avatar
Update: Did a valve lash just today and now its having couple of probs
It sounds like its only cranking on 3 cylinders
Have to give it gas in order for to idle and not die.
let me know what you think
havent changed the fuel injector yet but it started and idles before valve adjustment.
Old Sep 27, 2012 | 10:11 AM
v4lu3s's Avatar
RTFM
fix the problems you know of first before trying to tackle others...you may be surprised when something works better, plus you are less likely to burn your ecu out (which will eventually happen with the wrong injectors!).
Old Oct 1, 2012 | 02:20 AM
BIGef's Avatar
Update: started the car just to warm up.
revved the car all the way to 6800 and it just died.
decided not too touch the car and do the valve lash.
right after valve lash it sounded like one cylinder has no compression.
did comp test
#1-no compression
#2- 150
#3- 180
#4-180
did i bent a valve causing no compression?
Old Oct 7, 2012 | 09:26 PM
Grover Edmonds's Avatar
Nice link
Old Jan 21, 2013 | 06:33 AM
outage's Avatar
Did you ever fix the problem?
Old Jan 21, 2013 | 07:53 AM
BIGef's Avatar
yes i did, code 16 was leaking fuel injector.
and the no compression was wrong settings for the valve lash.
put stock specs and got good compression all cylinders
Old Jan 22, 2013 | 06:18 AM
outage's Avatar
Helpfull info. I'm having the same problems with the fuel injector code.
Old Feb 15, 2013 | 08:52 PM
89 elf's Avatar
i am having same problem with my 89 ef has code 16 but it sounds like its only runnin on two cyl smells really rich and is obd1 z6 swap. also throwing code 10 intake air temp sensor and it sounds like its bouncing off rev limiter early not sure what rpm no tac. any suggestions i need help.
Old Feb 15, 2013 | 09:42 PM
BIGef's Avatar
try and do a valve lash use stock settings.
make sure timing is correct and do a compression test.
for the code 16 check if theres and voltage going to your injectors.
for the code 10 try replace that sensor.
as for the bouncing rev limiter get yourself a tach and see whats it doing.
Had this prob last week. it would bounce around 4k it was my dizzy.
replaced it and everything is cherry
Old Feb 16, 2013 | 03:56 PM
M-benz's Avatar
Did you replace the whole dizzy or just the coil ? OR maybe the igniter ?
Old Feb 16, 2013 | 09:20 PM
BIGef's Avatar
the whole dizzy, only cause i had extra laying around
lamesa
Jan 2, 2015 04:06 AM
lsvSwagg
Jan 29, 2013 07:46 AM
93LsVx
Aug 28, 2010 09:20 AM
red91hatch
Jun 6, 2008 06:23 AM
cjohnson_2
Oct 30, 2003 10:02 PM
