CEL code 16
CEL code 16
Today my winter beater 92 civic dx had a little trouble starting. I just checked to see if it was throwing any codes and a code 16 showed up.. According to my Haynes manual its a fuel injector code.. Can someone explain this more? Is it the fuel pump? or an actual injector? BTW My car has run just fine since its trouble starting.
Re: CEL code 16 (cjohnson_2)
clogged injectors.. clean them out then also check the connection.. it could be a dead injector. but after you crank the motor remove the plugs on each cylinder and check for gas
93LsVx
08-28-2010 09:20 AM
