fs - 2.1 Scat stroker kit B series
I have a no mile, barely used 2.1 stroker kit for a 1.8L deck, it was test fit in block and turn over by hand only before removal.
The kit has:
scat 95mm crank,
matching scat rods,
arp/scat rod bolts,
je 13:1 pistons
rings, clips, etc
(note: compression ratio is for 1.8 bottom end with gsr head, you may use other bottom ends or heads, but the stroke and compression with be altered some and if used with a b20 bottom end you will be unable to use the pistons as the standard bore on a b20 bottom is is bigger), it is all internally balanced. This kit is discontinued and no longer offered through the company and was originally upwards of $3200+
I am asking $1800obro for the entire kit + shipping
no scarring or anything, just fingerprints and whatnot
The kit has:
scat 95mm crank,
matching scat rods,
arp/scat rod bolts,
je 13:1 pistons
rings, clips, etc
