Car dies out after re-torquing headsteads
Old Sep 15, 2012 | 02:12 AM
Choppedlude's Avatar
Default Car dies out after re-torquing headsteads
I have a built f22a1 block with a h23a1 head. I was gettig some issues with it so i was told to try re-torqueing the head studs. After getting it all back together an timed, i started the car, it ran great for 15 seconds or so, then started falling on its ***. RPMs drop and the engine sounds like its almost ready to die, and then it revs itself back up and sounds good for 5 seconds. This process repeats itself.
When we timed it, it was about half a tooth off on the intake cam, but with kt being a frankenstein engine, we assumed that its just how it should be timed.
Could i have messed up the original tune on it? Or should i look more into changing the timing on the intake cam?
Old Sep 15, 2012 | 02:14 AM
Default Re: Car dies out after re-torquing headsteads
Im just trying to get it to run to sell. If i cant, im just going to part it out. Ive got about $12000 in parts that i can make about $5000 off of if i sell them cheaply. But id prefer to make life easier on myself and sell the car as a whole
Old Sep 15, 2012 | 08:04 PM
Sorry for the autocorrect error in the title. Just now noticed it.
Old Sep 16, 2012 | 03:54 PM
InvaderTrax's Avatar
Unless you built it with the wrong timing parts, all marks should line up. If it says it's a tooth off, then you need to retime it
Old Sep 17, 2012 | 01:06 AM
Well it doesnt show a full tooth, which is weird. The car ran fine before i took it apart, there was a cooling pressure issue, so thats why i did it. But now it looks as though its going to have to be about a half tooth off retarded or advanced. Everything else lines up.
Old Sep 17, 2012 | 03:59 AM
nus_dogg's Avatar
I would make sure its dead even with its mark.
Old Sep 19, 2012 | 07:39 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
There is no such thing as "half" a tooth off. It is either in time, or it is not. If the timing mark is midway, look at the valve position and crank mark. Your problem may be timing related, but I doubt it has to do with the "half" a tooth issue....
Old Sep 20, 2012 | 06:21 AM
Acidcrakker's Avatar
Nice quote in sig, funny I dont ever remember saying that
Old Sep 21, 2012 | 08:58 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
LoL, you may not remember it, but it will live in infamy in the archives...
Old Sep 23, 2012 | 01:32 PM
oneday's Avatar
not experienced with frankenstein engines but does it sound like some kind of vacuum leak? most every time ive heard fluctuating idle someone just forgot to plug back in a line somewhere. just a thought
Old Sep 23, 2012 | 10:13 PM
I guess you'll have to bring that up to the 10+ year ASE mechanic.
Where its at now is slightly retarded on the intake cam. Move it one tooth advanced, and it lines up slightly advanced. To get the lines to match, the belt would be tooth on tooth, thats where were getting our "half" tooth off.
As for the vacuum leak, i've thought about it, but the only vacuum required to remove for this was the pcv
Wish i could give an update on this, but i havnt gotten around to doing anything about it yet. Sucks owning a house and having to do **** all the time.
Old Sep 24, 2012 | 07:11 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
LoL. Thats not half a tooth. Look at the valve position and the cam lobe position in relation to TDC. The timing may indeed be off (I dont know, Im not there) but it is not half a tooth off. That will not affect timing.
<<<<<<<<<<15 year Master tech. With an actual understanding of valve timing sequence and about 100+ timing belt jobs performed..
Old Oct 1, 2012 | 01:21 AM
I know how to read timing marks. If you did too, you'd know there are 2 marks, one to line up with the top of the head and the other to line up with the other cam. The intake one is off so slightly that if it were to be set on mark, the belt would line up tooth on tooth with the cam. Now, im no mathematician but seems to me that if it lines up halfway between 1 tooth, you get 1/2.
I think what you meant to tell me was "sounds like something off that slightly wont be causing your issue". So, thanks man i'll look somewhere else fir the issue.
Old Oct 3, 2012 | 06:20 PM
you bastard
jays1227
Aug 19, 2015 06:59 AM
accord2civic2prelude
Jun 14, 2009 04:14 PM
1phatEG8
12
Feb 5, 2009 03:02 PM
fed
Aug 25, 2004 08:15 PM
dogpile5
Dec 10, 2002 07:53 AM
