95 accord h22a no spark
I bought a 95 accord with a jdm h22a vtec motor in it that wouldn't start(no spark). figured the kid didnt know what he was doing and it would be and easy fix. I have replaced the main relay, distributor. that didn't work so I bought a whole different car with a standard tranny thinking I was going to switch it to standard and would just rewire the whole car at the same time. Now that the car is standard and has a whole new wiring harness it still has no spark. theres power going to distributor but nothing coming out. any ideas where to go now
Check out these:
https://honda-tech.com/forums/honda-prelude-4/car-wont-start-no-spark-3020919/
http://www.preludezone.com/general-t...ggestions.html
if its the Dizzy:
The black wire with the yellow tracer going to the coil should be hot with the key on or in the start position. The yellow wire at the distributor (may be inside the distributor- attached to the ignition module) should also be hot with the key on or cranking. The blue wire to the coil from the ignition module (may also be inside the distributor) should have a pulsed ground signal when the motor is cranked over. If you are missing any of these, the car will not start. If you don't have the ground pulse on the blue wire from the module, then either the module is bad, or one of the 3 pickup sensors are bad
if its the Dizzy:
No idea what yr the motor is out of. The distributor did spark in the donor car that I got the wiring harness out of and I took the entire wiring harness behind the dash fuse boxes relays everything. Was thinking it was a knock sensor but 95 accord don't have them so it would need the signal to spark. I think I'm not a wiring guy
Engine Is grounded and the car is obd1 I think motor is obd2. I'm pretty sure its got a be a motor sensor problem sense the donor car had spark. I just don't know where to go now
How many and where was the grounds when you looked at it?
socialistic
Jun 14, 2008 09:39 AM
superturboprelude
Jun 30, 2005 10:46 AM
