Need Help Confirming Viper 5901 Remote Start
Hi Guys, so I've just installed a Viper 5901 alarm on my '98 Civic and everything's working perfectly. I haven't had time to install the remote start just yet but I want to confirm that these would be the proper connections:
Page 9: http://alarmsellout.com/support/diag...01988-2006.pdf
H3/1 Pink (+) Ignition 1 Input/Output -> Blk/Yel Ignition Wire
H3/2 Red/White (87) Flex Relay Input (30A Fused) -> +12VDC Constant
H3/3 Orange (+) Accessory Output -> ??
H3/4 Violet (+) Starter Output (Car Side) -> Black/White (Car Side)
H3/5 Green (+) Starter Input (Key Side) -> Black/White (Key Side)
H3/6 Red Ignition 1 Input (30A Fused) -> +12VDC Constant
H3/7 Pink/White (30) Flex Relay Output -> ??
H3/8 Pink/Black (87a) Flex Relay Input -> ??
H3/9 Red/Black Accesory/Starter Relay Input (30A Fused) -> +12VDC Constant
H3/10 NC
I'm not too sure about the pink wires, some say I don't need H3/8, some say I need to hook it up to the second ignition wire??
Also, for which wires would I need for trunk release? I think I read before that it needed a relay to prevent amperage from overloading so I was a bit hesitant to connect my trunk wires.
Thanks
H3/10 NC
Thanks
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
H3/3 Orange (+) Accessory Output -> ?? Yellow
H3/7 Pink/White (30) Flex Relay Output -> ?? -------White black
H3/8 Pink/Black (87a) Flex Relay Input -> ??---------Not needed
H3/10 NC
Thanks
H3/10 NC
Thanks
dafuzzbudd
Audio / Security / Video
13
Oct 4, 2008 03:52 PM
