OBD2 distributor plug on OBD0 harness, OBD0-OBD1 ECU jumper harness
I'm trying to cross reference everything, and I just want to know if anyone can verify this.
using the diagram here, assuming it is correct: http://customcreationsabq.webs.com/a...s/show/7108739
and this diagram, assuming it is correct:
CYPG B12
TDCG B14
CKPG B16
CYPP B11
TDCP B13
CKPP B15
ICM A21
Those pin numbers would be coming off the obd1 ECU jumper. Is this correct? I have an OBD2 distributor plug, and the pinouts correspond
CYPG B12
TDCG B14
CKPG B16
CYPP B11
TDCP B13
CKPP B15
ICM A21
when i did this to my ef, i just matched to the same colored wire. the only slight confusion i had was the 2 whites with the yel/grn and wht wire
the only thing im not 100% on is the 2 wht wires and yel/grn and the wht wire but i did this 13 years ago
i use to say my car is alittle of all the obd years. obd 0 chassis dpfi-mpfi, obd0-obd 1 jumper obd 1 ecu, obd 2 motor, dist, and injectors
obd0 dpfi chassis, mpfi conv, obd1 ecu/jumper, obd2 distributor, injectors. same lol.
I had the cyp wires reversed. no codes now.
