not getting gas after 3-5k rpm
Old Sep 9, 2012 | 08:12 AM
mysuperslowej1's Avatar
Default not getting gas after 3-5k rpm
well my car starts real rough not getting enough gas i'll assume cause if i don't rev it a little it won't start. it dies in reverse. after i have it warmed up it won't start until after 5-10 times of cranking it i'm not getting cel codes for anything nor a light. i don't know if it's a vacuum leak or what but it's very aggravating and i'd like to fix it asap. when it starts to do this not getting gas **** if i just let up on the gas some it'll still go but i can't ever let it even go half way down. here's a video of it running i fixed the idle part for it though. and it's a pretty stock z6 just intake and y8 mani
https://www.youtube.com/watch?v=4pzd...&feature=g-upl
Old Sep 9, 2012 | 05:00 PM
Default Re: not getting gas after 3-5k rpm
bump
Old Sep 9, 2012 | 05:15 PM
Former User's Avatar
Does the CEL work? What car? What ECU?
Old Sep 9, 2012 | 05:40 PM
yes it works, ej1 and whatever stock is i think p06 maybe p28.
Old Sep 9, 2012 | 05:43 PM
The D16Z6 should have a P28 ECU. Check that.
Is there bright white spark at all 4 spark plugs?
Do all 4 injectors pulse fuel?
Have you checked the mechanical timing?
Old Sep 9, 2012 | 05:44 PM
yes i'm getting spark in all 4, i don't know how to check if all four are getting fuel, and yes i'm in time.
Old Sep 9, 2012 | 05:48 PM
You need to give details about how you checked spark and the mechanical timing.
Remove the fuel rail, unplug the distributor, and crank the engine to check spray of the injectors.
Have you measured the fuel pressure?
Old Sep 9, 2012 | 05:49 PM
well i put a screw driver in each spark plug cap, and i checked TDC on crank pulley and cam.
Old Sep 9, 2012 | 05:51 PM
Ryank327's Avatar
sounds like one of your injectors is stuck partially open and its getting flooded at start but being starved at higher rpms
Old Sep 9, 2012 | 05:58 PM
i don't have a the tool to do that so no.
what's away to check that/fix?
Old Sep 9, 2012 | 06:00 PM
You may be able to rent a pressure gauge at an auto parts store.
Have you checked the ignition timing with a timing gun?
Old Sep 9, 2012 | 06:06 PM
yes i'm getting spark in all 4...and yes i'm in time.
In the future, please include this type of basic information in the first post of any tech thread you create.
Old Sep 9, 2012 | 06:11 PM
will do, as for checking ignition timing no i'll have to rent the tool for that too. i've put my dizzy at all the way advance think that could anything to do with it?
Old Sep 9, 2012 | 06:13 PM
Rent the timing gun and pressure gauge and then go from there.
Also check whether all injectors spray fuel.
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
kraemer
Jun 9, 2010 11:20 AM
Stillo
Oct 15, 2006 10:53 AM
menappi
33
Jul 11, 2006 10:29 AM
DA6_toojy
Oct 12, 2005 06:30 PM
