Suspension & Brakes Theory, alignment, spring rates....
coilover question
Old Sep 9, 2012 | 06:24 AM
swizz977's Avatar
Default coilover question
ok so my coilovers are as low as they can go and the spring is all the way down has no preload
my question is to raise it for more ahock travel would you raise it by the spring or by the shock
what would the difference be and what would give more shock travel
Old Sep 9, 2012 | 10:53 AM
swizz977's Avatar
Default Re: coilover question
also another question.. im trying to adjust the ride height by the shock on the bottom with the spring all the way down.. i moved the shock down like an inch, then i drop the spring back down and when i put the wheel back on its at the same ride height.. i dont understand this and now when i jack the back up that wheel is lower then the other side when raised in the air.. suspension is so confusing
Old Sep 9, 2012 | 10:58 AM
grumblemarc's Avatar
The Grumpiest
It must suck to have paid so much money for suspension and not have it work out all for a useless trend.
Old Sep 9, 2012 | 11:17 AM
doood's Avatar
been there done that
Just think about your original question and apply some critical thinking. The answer is punching you in the face.
Old Sep 9, 2012 | 11:39 AM
MonkeyMagic's Avatar
because you have been riding around on the bumpstops, not the springs. keep cranking it up
this.
it's no wonder so many houses are burnt down each year by someone simply trying to use the microwave.
Old Sep 9, 2012 | 11:49 AM
swizz977's Avatar
its weird with everything all the way down.. i adjusted the ride height by raising the spring up a little and leaving the shock all the way up.. i tried adjusting it by lowering the shock but it was staying the same height.. i couldnt figure it out so i just raised it up by the spring..
EJ1_CRIS_909
Suspension & Brakes
12
Aug 23, 2011 10:09 AM
JDM_Type-R
Jul 8, 2004 02:39 PM
HondaCutter
Jan 26, 2004 08:28 AM
DiPPeD iN miLk Ej CoUpE
Jun 28, 2003 08:34 PM
