b16a swap in eg - no spark
I have a jdm b16a swap in my eg. It has been convetered form OBD0 to OBD1. I have changed the injectors, dizzy, and wirining harness. I am using a SOHC D-series harness on the b16a. Now here is the issue "NO SPARK". I have a P28 ECU.
I have checked wiring, coil, igniter, grounds (thermostat, valve cover, transmisson). I am using a GS-R Dizzy housing with D15b7 dizzy guts. New gs-r cap and i have a new d15b7 ignition rotor.. I see no spark marks inside the cap at all. I am getting power to my dizzy.
What could be my issue?
A P28 ECU is not a match for your engine.
Also click the spark link in my signature. Test the coil and igniter unit. Do the igniter unit input tests detailed in a diagram in the FAQs sticky.
done did all these test and all test out to be fine and a P28 ecu is the ecu u use to run a b16a swap in a eg.
i have no idea why i come on here and ask for help.. a stock p28 runs a b16a just fine.. i have done this many times.. was just very stumped on the dizzy thing.. i will order a new dizzy and try that and it should fix it..
Ueichi
Jul 28, 2012 05:38 PM
GSR_EJ2
16
Sep 3, 2009 07:02 AM
