Help with Viper 5901 Installation on 98 Civic
Old Sep 8, 2012 | 01:48 PM
tr666's Avatar
Default Help with Viper 5901 Installation on 98 Civic
Using page 9 of this for my car: http://alarmsellout.com/support/diag...01988-2006.pdf
And for the Viper 5901 harnesses:
http://www.directeddealers.com/manua...2008_08web.pdf
So I've been trying to install the Viper 5901 on my 98 Civic since yesterday and so far I have these connected:
Viper 5901 -------------------Car's wire color
H1/2 12V CONSTANT INPUT -> White IGN wire
HI/3 SIREN OUTPUT -> Red wire from siren and grounded to bolt
H1/5 CHASSIS GROUND -> Grounded to bolt behind driver's kick.
H1/8 DOOR TRIGGER INPUT -> LT. Green/Red behind radio
H1/11 PARKING LIGHT OUTPUT -> Red/Black wire above fuse box
H2 NOT USED
Door lock harness, 3-pin connected
1] BLUE (+) LOCK (-) (Both from behind the radio's green harness)
3] GREEN (-) LOCK (+)
H3/4 STARTER OUTPUT (Connected to car side)
H3/5 STARTER INPUT (Connected to key side)
This is all I've connected for now, I just wanted to test out the lock/unlock with the remote.
I can hear chirp (or just a noise) coming from the siren when I plug the H1 harness into the brain, but the problem is, no light whatsoever on the control center ever turns on. When I measured the voltage across the command center, it read as ~5V. Is this right? Or should it be 12V?
Maybe I have to finish connecting all the other wires first?
Old Sep 9, 2012 | 03:36 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Help with Viper 5901 Installation on 98 Civic
From the sounds of this. Its not a planned out install. You have wires going all over the place.. But to answer your question. MAke sure the fuse is going into the 12 output on the brain.
Old Sep 9, 2012 | 09:48 PM
tr666's Avatar
Nevermind, used the old remote and everything worked fine for some reason. Now the 2 way one works perfectly as well.
Thanks anyways!
BrotherAli
Audio / Security / Video
17
Oct 19, 2012 11:56 AM
Asmar
Feb 1, 2012 06:18 AM
DisOnesAPlaya
Jan 13, 2011 04:14 PM
himsweet66six
Oct 5, 2010 05:28 PM
technine
Aug 22, 2002 10:09 PM
