90 civic si - cranks but won't start
i have a 1990 civic si. i got it for free from a neighbor and replaced the fuel pump and filter, main relay and changed the oil. After i replaced the pump it ran for about 4 days and then i went out to start it and it only cranks. Please help me!
Please create thread titles that summarize the tech problem - edited. Otherwise your threads may be closed.
Start here:
When the key is turned from off to ON(II), does the fuel pump prime?
Is there spark at all four spark plugs?
Any CEL codes?
Start here:
Any CEL codes?
check your battery, had my car sitting for a bit because exhaust was broken, when put back together, it would crank, but not start. I tried to jump it, but it didn't help. Voltage was only 11.5 on battery so I got a new battery (old one was three years old) . The car started right up with the new battery! Hope this helps!
hamburgler
Aug 21, 2011 10:23 AM
k_vd16
Feb 5, 2011 01:42 PM
