RSX seats into 95 civic coupe
Old Sep 7, 2012 | 01:48 PM
95civicproject's Avatar
Default RSX seats into 95 civic coupe
YES I KNOW! everyone is going to think google search. i have multiple times to internet search this subject and i even checked the FAQs. i had a 2000 civic coupe that when i bought it had acura rsx type s leather seats in it. Probably the most comfortable seats i have ever sat in, in a honda at least. I am looking for a detailed write up on how difficult and how to get these to fit. i have not been able to track any down yet since i live in south carolina and to say south carolina has slim pickins when it comes to car parts is a drastic understatement but when i do find some i would like to know what it entails. THX.
Old Sep 7, 2012 | 02:06 PM
jbpnoman's Avatar
Default Re: RSX seats into 95 civic coupe
There's a reason people say search. Here's what I said to the last guy who asked.
Old Sep 7, 2012 | 04:30 PM
grumblemarc's Avatar
The Grumpiest
Methinks people need to beef up their search skills. The RSX or "insert your seat here" seat question gets asked at least once a month.
Old Sep 7, 2012 | 08:55 PM
mikekh10a's Avatar
del sol seats probably are the lowest there is i'd say
Old Sep 8, 2012 | 08:52 AM
ok so here is the actual question not bolting into ek couple or hatch like the thread says but if i was i would have never asked the question considering i found that under the FAQs but are the bolt patterns for eks and ej1s the same? since i do not know this i wouldnt think that i could use the ek one. If i knew they either were or were not the same then i would have worded the question differently.
Old Sep 8, 2012 | 10:33 AM
AlexIS350's Avatar
I have to agree those r comfortable seats
Old Sep 8, 2012 | 02:00 PM
jbpnoman's Avatar
...wat?
Old Sep 14, 2012 | 11:23 AM
are the bolt patterns for ej1s the same as the bolt patterns for ej8s? because i saw the FAQ showing how to put it in an ej8 just didnt see one on how to put them in a ej1
Old Sep 14, 2012 | 11:45 AM
The Grumpiest
What are you even asking about bolt patterns for? The end brackets had to be custom made. Expect to do the same for the 5th gen.
Old Sep 14, 2012 | 11:57 AM
sde780's Avatar
I think 2-3 bolts line up, the others will need you to fab up some brackets. Which really isn't hard at all if you have a welder.
Old Sep 14, 2012 | 03:30 PM
jbpnoman's Avatar
No.
Old Sep 15, 2012 | 08:33 AM
well if you dumb a**es are going to tell me to beef up my search skills maybe you need to learn to read im doing it into a 95 civic and the link that was sent to me was how to do it into a ej8 civic coupe if the bolt patterns arent the same how stupid do you have to be to give me a how to on a car with a completely different bolt pattern? that GRUMBLEMARC is why is asked if the bolt patterns were the same. try and follow along we wont use to big of words to confuse you
ok Thank you jp noman
Old Sep 15, 2012 | 08:44 AM
The Grumpiest
This is CUSTOM. CUSTOM!!! Custom as in, you have to rig up something SPECIFIC for YOUR application in order to make it work. Meaning that bolt patterns make absolutely NO DIFFERENCE. What part of that is escaping you?
This is going to require some CUSTOM fabrication. Which means you are going to have to get creative with how you are going to accomplish it. The link to the 6th DIY was given to give you an IDEA how it was done.
If you wanted a more OEM look you could cut off the tabs from your 5th gen rails and have someone weld them to the EP3 ones. That's what I would have done.
So if you haven't found a DIY you're going to have to be a pioneer and do it without one and stop worrying about bolt patterns that don't mater when you have to cut off the mounting tabs anyway.
Old Sep 15, 2012 | 09:28 AM
well bolt patterns DO matter cause if i was going to follow the DIY they linked me to then i would not have to worry and could do it EXACTLY as shown but now i know that the bolt patterns are different i know that i can only USE that DIY as a guide and not as a specific set of instructions. Thank you. lock thread now before you embarrass your self any more!
Old Sep 15, 2012 | 09:40 AM
four-doorlove's Avatar
the two fronts will line up one on the rear will line up i had this problem in my 93 coupe i had seats with ek brackets i bolten up the 3 that lined up and used a hammer to bend the 4th one and some call it ghetto but hell it worked and the seats are planted perfect.
Old Sep 15, 2012 | 09:44 AM
sweet sounds like i plan this was exactly what i was looking for thanks four door
Old Sep 15, 2012 | 09:51 AM
The Grumpiest
Get a welder.
JSR_SEDAN
Honda Civic (2001 - 2005)
10
Nov 3, 2011 08:53 PM
bbyass
Oct 8, 2009 02:41 AM
StockRsxDriver
Jun 1, 2009 04:19 AM
texasblackem2
Mar 6, 2009 01:20 PM
PearlBlueType-S
13
Jul 20, 2005 11:42 AM
