LS engine,GSR rods,Type R pistons?
Old Oct 16, 2002 | 05:06 PM
manis5speed's Avatar
Default LS engine,GSR rods,Type R pistons?
So anyone with a technical opinon? Will it work? Also, almost forgot CROWER 62402 with springs and retainers(of course). Lightnend flywheel, Skunk ecu, and adjustable fuel regulator. Seriously think it will work just not sure about the compression and clearances!
[Modified by manis5speed, 2:08 AM 10/17/2002]
Old Oct 16, 2002 | 06:09 PM
lsteggy's Avatar
Default Re: LS engine,GSR rods,Type R pistons? (manis5speed)
gsr rods wont work. the ls and gsr have a different stroke. keep the ls rods.
Old Oct 16, 2002 | 06:20 PM
Vu's Avatar
Vu
Default Re: LS engine,GSR rods,Type R pistons? (lsteggy)
GSR rods won't fit the LS crank. TypeR pistons should fit GSR rods
Old Oct 16, 2002 | 07:59 PM
Default Re: LS engine,GSR rods,Type R pistons? (Vu)
Ive heard about modifying the Type R pistons (boreing out the piston pin)? Is that possible? Also does anyone have any use for GSR rods pistons w/rings(used)?
[Modified by manis5speed, 5:04 AM 10/17/2002]
Old Oct 16, 2002 | 08:02 PM
PoWeRBaN_PaNdA's Avatar
itr pistons will fir on u r LS rods with little modification. It gives you an extra boost
Old Oct 16, 2002 | 08:06 PM
Default Re: LS engine,GSR rods,Type R pistons? (alpha_numeric)
What type of modifications?
Old Oct 16, 2002 | 08:48 PM
RenoRacing's Avatar
you have to have 1mm milled off of each side of the rod in order to get it to fit into the type R piston. it's not hard for a machine shop and not that expensive either, probably like 75 bucks for all if that.
Old Oct 17, 2002 | 03:13 AM
JCushing's Avatar
b16a pistons (p30) will fit on with no modification and give you 11:1 cr
i wouldnt even bother with the 402 cams... go with at least the 403's
if you keep the stock redline you dont even need the spring/retainer kit
Old Oct 19, 2002 | 11:07 AM
JBONES's Avatar
are ya saying ya want gsr pistons and rods.....
if ya need them i have a set 94 integra gsr 96,253 miles on them
swaped out them out for higher compression.....
what a $100obo (thats if ya need them)
boneshonda@hotmail.com..................let me know if interested
stoney0078
Jan 30, 2009 06:08 AM
BMo Tuning
Dec 7, 2008 05:06 PM
delsol456
Mar 5, 2008 05:50 PM
LSTEG96
Oct 23, 2003 09:38 PM
hitekper4mance
Jul 24, 2002 04:20 PM
