EM1 Front Bulkhead Measurements
You use the wax string to check for squareness between opposing corners. It's kind of hard to explain, so I'll throw together a quick paint pic to explain it.
Quick and sloppy, but hopefully this explains it better. As long as everything is square, you can use the wax string to measure the distance between opposing corners, and the distance should be equal. If the distance is unequal, either something is bent, or you're measuring incorrectly.
ShakesTheKlown
Jul 4, 2003 01:35 AM
