Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
code A 13
Old Sep 6, 2012 | 04:14 PM
gsr94's Avatar
Default code A 13
Called Honda. And was told I need a transmission flush, oil change and tire rotation. Took care of the oil change and rotation.
Question about the transmission flush its an 06 auto 66k miles btw. Does it require a filter change and where exactly is the transmission bolt/plug
Thanks
Old Sep 7, 2012 | 03:57 AM
97emsedan's Avatar
Default Re: code A 13
Unless you have around 40 liters of tranny fluid to flush your transmission with, and the pressurised pump unit to push it through the transmission, I would leave that tranny flush to the professionals. the filter gets replaced as well.
Old Sep 21, 2012 | 10:44 AM
ekb16's Avatar
honda does not recommend transmission "flush" with a machine and plus there isnt a proper way of hooking up a machine anyways..at our dealership when we do a transmission "flush" its usually just a 3x drain and fill..after each fill, drive it and run it thru all gears and drain again
palmtree
Feb 26, 2013 05:51 AM
1999CIVIC
Sep 17, 2003 01:00 PM
tarheelborn
Sep 10, 2003 09:14 PM
. o 69 o .
May 26, 2003 03:08 PM
