NY Turbo Ek hatch F/S F/T
1996 honda civic dx hatch back
Jdm b18b motor
Head:
Ferrea 6000 series valves
Oem valve seals
Supertech dual springs & retainers
Crower cams
Mild port and polish
5 angle job
hondata.i.m gasket
Edelvrock victor x manifold
Oem cam seals
Oem valve cover gasket
Ngk.v power spark plugs
Aem fuel rail
Block:
New pistons rings
Cometic head gasket
Arp headstuds
Oem thermostat
Oem alternator belt
Oem timing belt
Oem water pump
Oem tensioner
Pistons & rods are stock
Koyo radiator
Turbo:
Godspeed 50trim turbo
Greddy bov
Tial wastegate
Log manifold
Custom.piping 2.5 inches
2.5 downpipe
Transmission:
Gsr trans hydro
Synchro tech synchros
Energy suspension shifter bushings
Act pressure plate
Act 6 puck unsprung clutch just installed 9/4/12
Oem flywheel
Arp flywheel bolts
new bearing
Exterior:
2000 front end
2000 taillights
Si grill
Si front lip
gsr hammers
Apexi ws2 muffler 3 inch, its quiet for a 3inch but sounds real nice when u boost it
Interior:
Ls leather front seats
Si cluster
Short shifter
Carbon fiber airbag delete
Apine radio
C pillar bar
Step down harness
P75 ecu
Suspension:
skunk2 lowering springs
Front SI sway bar
New front wheel bearings
Function 7 lower control arms
Both new axles
Polished beaks bar
Gsr rear disk
Arp extended studs
Cross drill rotors front and back
Blackworks camber kit
avid motor mounts
...prolly missing a few stuff
Cons:
Needs rack and pinion
Need a tune
Need slim fan, currently using the oem fan but too big
Car runs healthy! No smoke at all!
Have paperwork for most of the parts
Oil changes every 2000miles mobile 1 synthetic with oem filter
All oem & aftermarket parts were bought brand new!
Have extra parts that I was gona.use for the motor:
Brand new in box 9.5:1 cp pistons 81mm
Brand new in box rc.550cc injectors
Brand new omni power 4 bar map sensor
Brand new in box acl bearings
...all u need is rods to build the whole block so it could be a fully built motor!
My tuner told me motor will push arpund 300hp as is right now, with built block and bigger turbo,should push 400+, depending on turbo size
Price: $4000 obo OR $4500 you get the car & parts that's listed above^(pistons alone cost $550)
Call or text 3473483916
Buyer will get a free bnib nrg slim hub
Will post pics as soon when.i get home!!
Reason for selling, I want back a integra, so I will trade for a mint gsr integra.
Jdm b18b motor
Head:
Oem valve seals
Crower cams
5 angle job
hondata.i.m gasket
Oem cam seals
Aem fuel rail
Block:
New pistons rings
Cometic head gasket
Arp headstuds
Oem thermostat
Oem alternator belt
Oem timing belt
Oem water pump
Oem tensioner
Koyo radiator
Turbo:
Greddy bov
Tial wastegate
Log manifold
2.5 downpipe
Transmission:
Gsr trans hydro
Act pressure plate
Oem flywheel
Arp flywheel bolts
new bearing
Exterior:
2000 front end
2000 taillights
Si grill
Si front lip
gsr hammers
Interior:
Si cluster
Short shifter
Apine radio
C pillar bar
Step down harness
P75 ecu
Suspension:
Front SI sway bar
Both new axles
Polished beaks bar
Gsr rear disk
Arp extended studs
avid motor mounts
Cons:
Need a tune
JDMH22HATCH
Jan 15, 2009 02:19 PM
