How to adjust the lifters?
Old Sep 3, 2012 | 08:15 PM
Ryan Lwin's Avatar
Default How to adjust the lifters?
Hey guys, as I was doing some cleaning to my D16Y8 engine, I took out some lifters from rocker arm assembly to clean. I guess I put them back the wrong way or something but now, my engine is making a knocking sound. Anyone knows how to adjust those? I can't find it in FAQ or anywhere.
These things under the cover.
Old Sep 3, 2012 | 08:19 PM
jbpnoman's Avatar
Default Re: How to adjust the lifters?
Valve Lash Adjustment. That's what you need to look up.
Old Sep 3, 2012 | 08:22 PM
Ryan Lwin's Avatar
Thanks. You da man!
Old Sep 3, 2012 | 08:23 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
wait you took part of the valve train apart and mixed parts up? you are supposed to put everything back in the same place it came out of ,everything wears in a certain way if something has always been in a certain location it's worn unique to it's place on the cam, you never mix up parts like this, that's one of the most basic rules of doing engine work,keep everything in order
Old Sep 3, 2012 | 08:26 PM
Ryan Lwin's Avatar
Ah. Valve lash adjustment adjust valves gap right? Not the little cylinders inside the rocker arm assembly?
Old Sep 3, 2012 | 08:28 PM
Ryan Lwin's Avatar
I didn't try to. One of them jumped out. The other 3 stayed the same. And I had the cam at TDC. So, I thought if I line up with the hole on the little cylinder and the whole on the cover, it would be correct. I guess not. Any suggestion?
Old Sep 3, 2012 | 08:45 PM
Ryan Lwin's Avatar
Ok. They are called "Lost Motion Assembly".
Is it possible to adjust them back to spec?
Old Sep 3, 2012 | 08:50 PM
Ryan Lwin's Avatar
Well, good news. I just need to replace new ones. No need adjustments.
Bad news. Knocking happened because I didn't lube them when I put in thinking engine oil will get in there by itself. FML. They are shot now.
SOHC_me
Jul 13, 2007 10:33 AM
fatboi07
Aug 14, 2006 09:17 AM
kornerk12
Dec 18, 2005 03:27 PM
redpeppers
Jul 26, 2005 02:33 PM
