gsr swap help!
Alright guys im putting in a gsr into my 95 civic but ran into some problems:/ this is my first swap. i cnt plug n play with the harness becasue the the alternator,dizzy and fuel injectors are obd 2
So wat could i do? could i replace them with my d series dizzy alternator n fuel injectors??thanks!
Us your swap JDM or did it come with its harness?
1. For the injectors as long as your Civic was an EX/SI/DX you can use your injectors
2. For the alternator you can try this or solder on the OBD2 alternator plug
http://www.hamotorsports.com/obd2-al...1-harness.html
3. Distributor can just use an adapter or solder/swap the OBD1 connectors on your GSR distributor
chrisc543
Feb 19, 2014 07:22 PM
vtec25
Oct 9, 2005 05:49 PM
