Honda S2000 Honda S2000
S2k Loses power after vtec engages
Old Sep 3, 2012 | 04:11 PM
SoLo26's Avatar
Default S2k Loses power after vtec engages
I have A 2002 S2k and when I hit vtech it gets to about 7k and feels like its losing power, I've searched for answers but can't seem to find anything that fits the problem I'm having. Help is much needed so if can help it would be appreciated. Plz keep all negative and useless comments to yourself thanks.
Old Sep 3, 2012 | 04:23 PM
postman's Avatar
Default Re: S2k Loses power after vtec engages
are you even sure the vtec is engaging? if so how did you determine this.
Old Sep 3, 2012 | 04:31 PM
SoLo26's Avatar
To be honest I'm not sure it sounds like it is but i could be very wrong
Old Sep 3, 2012 | 05:33 PM
SoLo26's Avatar
I forgot to mention that it threw a code today for the 02 sensor, could that be a reason why its not hitting vtec
Old Sep 3, 2012 | 06:07 PM
JulieU's Avatar
Check your oil level. If it's sufficient, maybe check your VTEC solenoid screen as it could be clogged. Other things you could try are resetting the ECU by pulling the backup fuse and doing a MAP whack.
Old Sep 3, 2012 | 06:38 PM
SoLo26's Avatar
checked the oil, reset the ecu, it was cutting out at 6k b4
Old Sep 4, 2012 | 06:08 AM
JulieU's Avatar
Are you letting it warm up first? There's a cold rev limiter that won't even let you into VTEC range until it's reached a certain temperature.
Old Sep 4, 2012 | 07:23 AM
SoLo26's Avatar
Yea I already know about that
Old Sep 6, 2012 | 07:26 AM
SoLo26's Avatar
And it does the same thing in every gear not just 1st
Old Sep 15, 2012 | 10:54 AM
superman em1's Avatar
are you running cats?????? i had the same problem with my old si and i put in a test pipe and it salved the problem
Old Sep 17, 2012 | 11:50 AM
Marcpb443's Avatar
Old Sep 19, 2012 | 07:38 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
If your VTEC solenoid screen is clogged, you'll have the issue you're describing. I had that issue with a prelude that I swapped before. I had a clogged cat do the same thing....actually...on another prelude.
Are you sure your check engine light works? It sounds like maybe the ECU doesn't know if the car is fully warmed up.
1sgranger75
Honda Civic (2001 - 2005)
Sep 27, 2010 08:59 PM
909dc2
Oct 17, 2008 03:32 AM
Cyber ITR
May 7, 2006 09:46 PM
tuckin15s_8315
Sep 28, 2005 10:12 PM
ATF Kuk
May 1, 2003 12:20 PM
