'94 Del Sol 3rd brake light inoperable.
The 3rd (center) brake light on my Del Sol is not working. Has not worked since buying. All other brake lights are operable. Tested wires and it IS getting 12V when brake pedal pressed. I thought it may be the bulbs, but they're LED's and none of them are coming on when pressing the brake pedal. Help.
I ran a pigtail wire from the light to a ground and still nothing. I did noticed a couple broken bulbs inside the lense sliding around. But it looks like a typical light that may need to be put into the oven to separate the lense from the backing? Maybe I just need to buy a new light.
Just wanted to conclude this thread, the light was getting the proper power it was just crapped out. Bought a used one from a junkyard for $20 and it works perfectly. Thanks for the help.
78F350
Jan 24, 2012 10:03 AM
[Rush]
21
Apr 12, 2010 08:18 PM
