Del Sol panel Brake light stays on
Old 01-15-2012, 02:22 PM
78F350's Avatar
Default Del Sol panel Brake light stays on
Its a 93 Del Sol S that the instrument panel "BRAKE" light stays on *Unless* the headlights are on, then the light goes out.
Has anyone seen this before or have a good idea where to look?
Additional info...
With the car running and headlights on the light does not come on even with the Parking Brake set. If I turn the car off then and leave the headlights on the "BRAKE" light comes back on. I'm thinking it's a relay issue, but I'm not sure where to start. Brake fluid level is good.
The driver's side window doesn't work either right now, but I suspect that's a separate issue.
Old 01-24-2012, 09:20 AM
78F350's Avatar
Default Re: Del Sol panel Brake light stays on
Fixed.
After tracking down the wires I found that the wiring for the cigarette lighter had burned through the insulation and shorted the wire to the switch on the parking brake. Cut off the burned out wires, ran new and its good.
Old 01-24-2012, 10:03 AM
MonkeyBoy668's Avatar
Melted cigarette lighter wire? I bet a previous owner tried to start their car using one of those god-awful cigarette lighter "jumper cables."
Good work on the fix!
I hate working in my dash, always worried I'm going to unplug or break a completely unrelated wire. Stupid body, be more coordinated.
97delslo
07-29-2015 12:59 PM
Will Scott
04-29-2014 05:23 PM
B33FCAK3
09-12-2012 04:27 PM
[Rush]
21
04-12-2010 08:18 PM
scottyieoittie
04-08-2008 11:58 PM
Quick Reply: Del Sol panel Brake light stays on
