***HELP*** GSR B18C1 OBD1 into 97 EK Civic Hatchback OBDII with OBD 2 ECU
i got B18C1 engine OBD1 planning to swap in my 97 EK Civic Hatchback OBDII with OBD 2 ECU
what i needed have to before running motor in my EK.
Can anyone help me? Thanks in advanced.
You will be using your stock engine harness on the gsr engine. If it were mine I would get OBD2 accessories to match your harness. Injectors are different. I believe the alternator and distributor are different. Oil pump is going to need the CFK sensor and will need to be changed. Your other option is to graft the OBD1 plugs on the stock engine harness for the injectors, dist, alt.
If you need an OBD2 gsr ecu I have one I need to sell. You can make me an offer if you need it.
daeaudio
15
Sep 17, 2005 11:21 AM
tour de france turbo
Aug 20, 2005 06:36 PM
