grinding sound on engine start
sounds like a transmission grinding off teeth after it cranks over when it starts
Heres what you would hear if you were here:
"crank crank :grind:vrooom "
the sound is right when the engine turns the crank on its own.
Someone said "have ya tried to start the car while its running..?"
(hehe
yes once - who hasn't)
"that's it"
So my starter's grinding when it.. starts? what?
thanks hondatech'ers ~ Peter
(hehe
yes once - who hasn't)"that's it"
You might have to replace the starter. Normally the pinion gear at the end of the starter returns back to it's sitting position, which is down. you might want to ask around. it normally cost $50 for a remanufactured starter with exchange, just hold on to your receipts.
check your rotor in your distributor it may be going bad.
starts perfect, just makes that noise, revs to 7500 without hesitation or needle bounce
sounds like the fly wheel ring gear are worn in 4 spots i bet. if it turns over the starter is still good. but when u change the flywheel ring gear its a good idea to change the starter also so you break in the teeth. so its a matching set and will last longer also.
[Modified by lamchop0000, 7:20 PM 10/16/2002]
sounds to me like the starter doesn't know when it has finished it's job. try taking it to a parts place that tests starters to see if it is a starter problem.
mynameizstitch
Mar 17, 2012 10:55 AM
accord2civic2prelude
Nov 12, 2010 11:07 PM
