95 Civic DX, help catching the CEL code
Old Aug 28, 2012 | 08:39 PM
Ryan Lwin's Avatar
Default 95 Civic DX, help catching the CEL code
I got a 95 Civic DX with Y8 engine, manual with auto Y8 manifold modified to work with manual IAC, GSR tb. The problem is, every morning when I start cold, after a while of driving, it throws CEL. It only does that once per day on the first drive of the day. I've been trying to catch this CEL by jumping as soon as it comes on with engine on and without engine on with key in ON position. It shows no code. I cannot make it to throw the same CEL in same day. I have to wait overnight parking to make it come on again. It only comes on while driving too. At first, I thought it was the VTEC sensor but it wasn't the case. VTEC works just fine.
Any idea how I can catch this CEL? Ask me for any details.
Old Aug 29, 2012 | 05:38 AM
Former User's Avatar
Default Re: 95 Civic DX, help catching the CEL code
Click on the Codes sticky at the top. The first post has a helpful tip on how to solve this problem.
Old Aug 29, 2012 | 05:52 AM
Ryan Lwin's Avatar
I have followed the procedure. I have been. I even saw the one where if the code gets clear, jump it as soon as it comes on by parking on the side with engine on. Still got nothing. That's why I'm at lost. Any tips?
Old Aug 29, 2012 | 06:19 AM
When you pull over with the CEL on and leave the engine idling, no codes blink from the CEL when you jump the service connector? The CEL just remains on steady?
Does the CEL remain on after you pull over with the engine idling? And it remains on until you jump the service connector?
Old Aug 29, 2012 | 07:11 AM
Ryan Lwin's Avatar
CEL just blink steadily. No code.
Old Aug 29, 2012 | 07:25 AM
Blinking steadily IS a code. Post a video of the blinking CEL.
Old Aug 29, 2012 | 01:05 PM
Ryan Lwin's Avatar
I waited for 2 minutes thinking it might change the frequency of the blink but it didn't. Just sane over 30 blinks. Same as how it blinks after clearing and resetting ECU. I'll make a video tomorrow morning. Have to wait for a day.
Old Aug 29, 2012 | 02:55 PM
Ryan Lwin's Avatar
Ah. I think it's code 10. I have AEM cold air intake and since the car came with auto y8 manifold which I modded to work with manual IAC, I didn't drill hole for IAT. Instead, I drilled a hole on my intake between the throttle body and the hole where the small hose that comes from engine is connected. I placed the IAT there. Do you think that is the problem? If so, why does it only come on once a day on cold start after a few major load on the engine such as leaving the traffic light or going up the freeway ramp, after engine reach operating temperature
Old Aug 29, 2012 | 10:40 PM
Solster's Avatar
Pix of the Mod please.
also please post the ECU id code p##-XXX section
Old Aug 30, 2012 | 04:49 AM
Ryan Lwin's Avatar
It's OBD1. I have to wait till I go to school and take video on the way. I drilled the hole underneath the intake and plugged it in.I'll take picture.
Old Aug 30, 2012 | 08:10 AM
Ryan Lwin's Avatar
Here's where I put IAT. I hope this doesn't make any differences.
This morning before I leave for school, I took out the intake to take picture. While at it, I measured the resistance of the IAT. It was 2.2k ohm at 70' F and it was slowly going down by 0.001 ohm. I measured the voltage of the lead and it was 5 V constant. I put the intake back on. Drove to school. No CEL so far.
That95coupe
Jun 4, 2015 07:47 PM
ZCboost
Sep 21, 2010 09:49 AM
dave181
May 20, 2009 08:47 PM
