If a car is misfiring in a certain cylinder does that mean it's plug/wire?
Old Aug 28, 2012 | 02:29 PM
Kohen's Avatar
Default If a car is misfiring in a certain cylinder does that mean it's plug/wire?
Let's say my car is misfiring is cylinder 3. Does that pretty much limit it to being cylinder 3s spark plug or wire?
Old Aug 28, 2012 | 03:32 PM
98.4DR.EK.D16's Avatar
Default Re: If a car is misfiring in a certain cylinder does that mean it's plug/wire?
not exactly. i had a misfire in only cylinder 1 and it turned out the be the harness. i ran a straight wire from the injector the the ecu and voila
Old Aug 28, 2012 | 03:41 PM
Kohen's Avatar
Oh okay. Thanks for the info.
Anyone else have something to say?
Old Aug 28, 2012 | 04:00 PM
InTheZoneAC's Avatar
Specific cylinder:
-plug, bad
-wire, bad
-fuel injector, clogged or stuck open
-fuel injector wiring clip, no voltage
-blown headgasket
Old Aug 28, 2012 | 04:15 PM
Kohen's Avatar
Originally Posted by InTheZoneAC
Specific cylinder:
-plug, bad
-wire, bad
-blown headgasket
Fantastic answer. Wish we had "rep" on here, I would +rep you.
Old Aug 28, 2012 | 04:19 PM
Just realized that you still have my quote as your sig lmfao
Old Aug 28, 2012 | 04:28 PM
Kohen's Avatar
Hahahaha. Awkward...
Old Aug 29, 2012 | 06:00 PM
beecee18's Avatar
On the mechanical side a missfire could be from incorrect valve clearence(hanging valve) and any other compromise of compression levels needed for correct and complete combustion wether being in the head or block.
Missfires from compromised fuel systems, mainly individual injectors wouldnt be the cause if you are loading up unspent fuel in the exhaust system during the missfire condition(rich, smelly fumes)unless the injector is stuck open.
move injectors from problem cylinder to a known good cylinder and see if the problem moves with it.
Do the same with the plug, wires, ect.
then finally check compression if all else fails.
Old Aug 29, 2012 | 09:48 PM
Kohen's Avatar
Mmkay, thanks.
thunderboy
Apr 24, 2010 08:39 AM
B18CivicHatch
Aug 24, 2007 12:13 AM
951dc5
Nov 26, 2004 05:33 PM
hontegra
Apr 11, 2004 07:03 PM
A_W_D_Turbo
Feb 8, 2003 05:22 PM
