2002 Honda Civic Knocking noise when letting off gas pedal
I noticed today when I was driving that whenever I let off of the gas pedal I could hear a single knocking type of noise. It isn't too loud or anything and it's only when my car is in gear. I have a 5 speed Honda Civic Ex. Also I noticed it happens sometimes when I press down the clutch also. Any ideas on what possibly could be the problem?
could be input shaft bearing if the noise only happens in gear. If you are sitting with the car in neutral and the clutch engaged can you still hear it? Then it goes away when you press the clutch in?
It could be two things the Crankshaft is goin or in some cases your compressor could be shaking when the engine is running that happened to me before I had that knocking and swore it was the crankshaft but when I mounted it and took a closer look it was just my compressor rattling lol
GreyPunk67
Honda Civic (2006 - 2015)
Sep 27, 2017 04:37 AM
wstewart90
Honda Civic (2001 - 2005)
Jan 15, 2013 02:39 PM
Hayes19194Ua
May 4, 2010 09:44 AM
