can obd1 code 8(TDC) be because of this? look inside
Old Aug 27, 2012 | 10:26 PM
Marvin1985's Avatar
Default can obd1 code 8(TDC) be because of this? look inside
z6 motor y8 mani 2 wire iacv
horrible idle and boggs. I went thru hell with iacv fixes and crap. I did take apart and reassemble the dizzy and i think I flipped the coupling in this link 180* which is causing all this headache with code 8 and 14. can someone confirm all this?
Reason i took apart dizzy is cuz its a z6 in a 99 civic with a p28 obd1 jumper and y8 mani with 2 wire iacv, but i didnt wanna splice wires from the z6 dizzy so i simply swapped casings with the y7 one and am using the y7 dizzy wiring/ internals in the z6 dizzy case.
znjdevils07
Apr 29, 2011 02:19 PM
extensioncordy
Oct 6, 2007 09:11 AM
inh
Jul 30, 2006 06:38 PM
skunk2eg
Jan 13, 2006 10:18 AM
