94 dx coupe no power to injectors
Old Aug 27, 2012 | 03:07 PM
pokedacatfish's Avatar
Default 94 dx coupe no power to injectors
I have a 94 coupe it died on me a few days ago it's getting no power to the objectors it has s b16 in it I changed the grounds tried another ecu could it b the dizzy without a cel I have no clue what to try help plz
Old Aug 27, 2012 | 04:02 PM
98.4DR.EK.D16's Avatar
Default Re: 94 dx coupe no power to injectors
possibly your harness, check harness from ecu til injectors. i experienced this issue when i had cylinder one stop firing due to no injector power. ran a straight wire from the ecu to injector and voila
Old Aug 27, 2012 | 05:53 PM
Former User's Avatar
Fuel pump prime?
Spark at the plugs?
Old Aug 27, 2012 | 06:54 PM
Originally Posted by RonJ@HT
Fuel pump prime?
Spark at the plugs?
good suggestions since he says its all cylinders that arent firing
Old Aug 28, 2012 | 11:39 AM
I'm gettin fuel to the rail in getting spark car starts with starting fluid I'm goin to go through the harness could it b my dizzy inside when I took the cap off it was real dirty almost looked like rust I cleaned it changed the cap and rotor could it b
bad ignition timing
H22SHtec
Sep 25, 2023 09:17 PM
gs-r94coupe
Oct 22, 2010 10:06 PM
carracr625
May 12, 2010 01:48 PM
firecivicman
Jun 30, 2007 08:41 PM
hooddub
Aug 23, 2006 02:01 AM
