Code 41, no voltage in harness
So I'm getting a code 41 currently on my car. It's swapped with a JDM B16A. I checked the sensor and it's between 10 and 40 Ohms. I then proceeded to check for voltage and I found none. I used the "My VTEC doesn't work" FAQ for all of this by the way. So now my question is where do I go from here? All it says for the next step is "repair open on the yel/blk wire that is used on the o2 harness and the pgm" I believe. So I assume that this basically means check to see why no voltage is getting to the wire but I need some help on how to go about doing this. Thanks
Ah ok, well I assumed it would be the same for the 96-99 civics so my bad. Anyways I checked 15 and it had a 20amp fuse in it instead of a 7.5amp. So i replaced ti with a new 7.5 and it's still throwing the code.
Well that's good to know. At least it's not a bigger problem. So basically should I just trace the wire back and look for the break? And if so how would I look at the wiring that's actually inside the engine harness?
Jimi Hondrix
Jun 17, 2015 12:21 PM
