04' Civic SI rear caliper drags after break job
Old Aug 26, 2012 | 01:06 PM
Miho1269's Avatar
Icon3 04' Civic SI rear caliper drags after break job
Just replaced the pads and rotors on a 2004 civic si and for some reason after the job the driver side rear caliper is draging so bad its smoking. replaced the rotors with a set of no name drilled and slotted rotors that came with a set of ommni 5 pads please let me know of any reasons this is happening ASAP thanks
Old Aug 26, 2012 | 01:53 PM
EM2abe's Avatar
Default Re: 04' Civic SI rear caliper drags after break job
but...... you might just wanna take it all apart and re-do it all and make sure everything is straight and true and also make sure that you are using all the correct parts with the correct part numbers and all that.
Old Aug 26, 2012 | 11:54 PM
poeticfinesse21's Avatar
Sounds like your rear caliper might be seized, it's a common problem with EP3's. I had a similar problem and only replacing the caliper fixed it.
Old Aug 27, 2012 | 02:54 AM
prelude_h22vtec's Avatar
If it is dragging, the slide may be seized or it may be the piston itself not returning like its supposed to.
Getting a new caliper is probably the only sure way to fix it.
Disassemble it all, make sure you got it all right. If it still drags, replace the caliper.
rgar98
Honda Civic (2006 - 2015)
Mar 23, 2015 03:57 PM
SHG_Claudio
20
May 12, 2010 07:41 AM
chameleon
Mar 3, 2005 08:57 PM
kevinoneill
22
Feb 21, 2004 08:24 AM
Train
Dec 8, 2003 07:28 PM
