... car problems... please help... (compression / leakdown test)
problems :
- burns oil (needs about 1/2 a quart a week)
- burns coolant (need to refill overflow reservoir every 1 1/2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, esp. at wot)
- light smoke from under the hood
- sometimes hard to keep idle without stalling (stopped happening after going to the darkside)
- lower than expected performance (191whp/165tq, see sig for setup) (i was expecting 220-250whp)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or cracked ring lands (what are these and how can i check if this is the problem? pull the head, right?)... or cracked sleeves...
... i was also told to do both a compression and leakdown test... i was wondering... after doing these two tests... how will i know if there is a problem?... and then once i pull the head to replace the headgasket what should i look for to check the ring lands, piston rings, and sleeves?...
... thanks for taking the time to read... any help is really appreciated... thanks...
[Modified by 1.8T_EG, 12:39 PM 10/16/2002]
Guest
Posts: n/a
I was burning coolant for a while because I hadn't used all the nuts ( I know,
) to hold the intake manifold on. Since coolant passes through the mani it was leaking into the #4 cylinder, check your plugs, I had a green #4 plug.
I don't think you can tell if it's broken rings/lands by just pulling the head, I think you have to pull the rods/pistons.
The logic goes if you've got low compression in a cylinder add a teaspoon of oil in the sparkplug hole and recheck. If the compression goes up it's a problem with pistons/rings. If it doesn't it's valve stem seals/guides.
I think sleeves will be obvious once you pull the head.
No blue smoke under WOT though? Hmmmm....
PS Just as an aside, it's fucked up that I started off just wanting to go fast, I end up knowing how to fix damn near everything on my car.
[Modified by filetofit, 11:45 PM 10/16/2002]
) to hold the intake manifold on. Since coolant passes through the mani it was leaking into the #4 cylinder, check your plugs, I had a green #4 plug.I don't think you can tell if it's broken rings/lands by just pulling the head, I think you have to pull the rods/pistons.
If you do a compression check, that can pretty much solve your problems. If they all come out pretty high and within 10-15psi of each other, then you are probably ok. But, if it comes out low it could be a few things. Blown headgasket, cracked ringlands, burnt up valve, or at worst, a cracked sleeve. Once you pull a compression test, you can find out where it is low.
From there, you can get a leakdown performed and this will tell you where exactly you are leaking compression from. After you find this out, you will pretty much pinpoint the problem. Good luck dude....
problems :
... just did a compression test... here are my numbers
1 : 180
2 : 178
3 : 185
4 : 185
... great numbers, right?... ((makes me feel a little better))... but now i am totally confused about what my problem is... wtf?!?!?... so now what?... like i said before :
problems :
- burns coolant (need to refill overflow reservoir every 1-2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, but not always, but esp. at wot)
- blue smoke from exhaust (sometimes, but not always)
- light smoke from under the hood (sometimes)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or o-ring... or worn valves or cracked ring lands (what are these and how can i check if this is the problem? pull the head, right?)... or cracked sleeves...
1 : 180
2 : 178
3 : 185
4 : 185
problems :
SPOONfdEK
Jun 24, 2004 02:45 PM
