MPFI conversion help
Old Aug 25, 2012 | 10:04 AM
DA9racer's Avatar
Default MPFI conversion help
ok so i converted my D15b2 to mpfi and it starts and idle's fine the issue im having is that 1 im getting a code 14 for the IACV but i changed it out and i still have the code and 2 at any speed in any gear it act's like its hitting the rev limiter but only if i try to steady the throttle, if i speed up or slow down its fine other then the miss it seems to have on acceleration but on a steady throttle it "bounces" really bad.
ive changed out the ecu, dizzy, iacv, res box, and tested the tps.... ive redone the timing and it still has a "missing sound". ive rechecked and rechecked and rechecked the wiring but that all seems perfect
. . . . HELP PLZ I NEED TO GET IT RUNNING BETTER SO I CAN SMOG IT
sanman000719
Apr 14, 2013 05:43 PM
88efsedanlx
Dec 10, 2011 05:40 PM
Run Away
35
Jun 1, 2008 04:14 PM
SomeDude56
Sep 26, 2005 02:31 PM
NFM_Dm
Sep 5, 2004 11:47 AM
