cpr users
Old Apr 14, 2013 | 04:11 PM
sanman000719's Avatar
Default cpr users
we are having a few issues that some of you might be able to help out with
we are getting a error code 9 (tdc)
and it doesnt seem to be censing the right tooth while cranking and trying to start there is alot of backfire then it starts.
then we are missing at 7k rpm during tuning.
anyone havingor had these types of problems
Old Apr 14, 2013 | 04:21 PM
CO_RaceFab's Avatar
Default Re: cpr users
Make sure the box isn't to close to the ecu and triple check the wiring.
Old Apr 14, 2013 | 04:38 PM
lsvtecracer's Avatar
I am having almost the same issue with the CPR setup on my car. I'm not getting tdc code but it won't rev past 6.5-7 rpm. It would also shut off the engine when I launch hard or when shifting. Another dist will usually fix it for 5 -6 passes then back to breaking up again. I have gone through 4 dist and miss 1race because of it.
Old Apr 14, 2013 | 04:49 PM
seelback's Avatar
Installed mine a while ago and had no issues. The only thing i could say is make sure all your wiring is good, make sure all your pins are tight, all your solder joints are still holding, inspect the sensors inside the dizzy, make sure there are no interferences with the cpr box.
Old Apr 14, 2013 | 04:52 PM
turbo boost's Avatar
i had a same issue ...it turned out to be when i wired it up i spliced into the 2 wires at the dizzy , instead of using the suplied pins...so the factory igniter was still hooked up in the dizzy....unhooked all the wires going to the igniter and took the igniter out of the dizzy and the issue went away....not sure if this will help or not...
Old Apr 14, 2013 | 05:13 PM
cjordan's Avatar
had same issue a while back turned out being my s300...
Old Apr 14, 2013 | 05:17 PM
the ingnitor is out
my tuner did all the wiring i dropped the dizzy/rywire harness/cpr kit off with him and he soldered it all togather according to hondata.
this thing just doesnt seem to be able to find tdc for some reason it throws the code, and brakes up.
i was using a metal nokya spark plug cover and screwing it down so i took it off and the car seems to start alot better(easier) now so i just ordered a rywire coil hold down, and 4 s2000 coils. im thinking i might have cracked some of the other coils with using the spark plug cover. the coils are very tough they crack easily
the box is about 6" from the edu but i can unmount it and relocate to see how it goes i guess
Old Apr 14, 2013 | 05:24 PM
also make sure the ground for the cpr kit is good and clean and hooked to the thermostate housing
Old Apr 14, 2013 | 05:43 PM
cleaned it off before putting it on the t stat housing
we think its the distributor not being oem that is causing the tdc error i took a chance on it from ebay and my tuner thinks this is the issue now.
ill get an oem from the junk and set it up
monster d
Jun 12, 2013 10:20 PM
2ndchirp
13
May 9, 2010 04:45 PM
Rick777
Feb 5, 2010 12:56 PM
SETI20
Jul 10, 2004 06:44 AM
type Gendy
Aug 2, 2003 05:44 PM
