Hard time starting car up
Old Aug 25, 2012 | 07:04 AM
AccordBoy88's Avatar
Default Hard time starting car up
i just bought a 01 integra auto
when i try to crank it to start up the car shuts off sometime and sometime when i start it first time it come on and the idle is very low and feel like its going shut off but after few sec it goes back to normal idle. the 2nd and 3rd time i crank it. it starts fine.
previous owner raplaced battery, spark plug and wires, air filter, fuel filter.
could it be the main relay?
any idea what it could be?
Old Aug 25, 2012 | 10:06 AM
el crapitan's Avatar
Default Re: Hard time starting car up
you already made another thread about this. have you tried what i'd suggested?
https://honda-tech.com/forums/acura-integra-6/car-hesitate-start-first-3082510/
Old Aug 25, 2012 | 02:54 PM
mangogsr's Avatar
i have a 97 gsr and i have sort of the same problems. it cranks about 3 times and barely catches. then idle goes up then down. it idles about 500 rpms. i heard to check battery cables. make sure of good connection.
Posted from Honda-tech.com App for Android
Old Aug 25, 2012 | 04:48 PM
Navy_Kyle's Avatar
check your thermostat ground, transmission ground and valve cover ground.
david1227
Jun 2, 2013 11:50 AM
Hyoriu
Sep 16, 2012 06:00 AM
MilFhunter001
Jun 1, 2010 06:55 AM
jdm5lughatch
May 14, 2004 07:37 PM
blktyprgrl
Oct 7, 2003 06:44 PM
