D15B swapped, need timing belt part number
Old Aug 24, 2012 | 06:25 PM
zx92027xz's Avatar
Default D15B swapped, need timing belt part number
I did an engine swap about 18 months ago in my 96 civic dx (D16something stock). I recently did a timing belt replacement, and I'm fairly sure I put the wrong belt in it.
After ensuring both crank and cam pulleys were at tdc (3 times, I took it apart twice to the check) it still ran like crap.
Today I went and picked up the timing belt for the 94 civic 1.5 liter motor, and I'm entirely sure that it's still not the right belt because it's a fair amount too long. (tensioner at its max tightness and still wayyy too much slack)
I am unsure of what year/model the d15b motor came out of (bought through hmotorsonline) so I am lost as to which belt is supposed to go on it.
To be clear, this is a "D15B" motor with no number after the B.
The part numbers for the belts I have tried: T143 and T224
Please help?
Last edited by zx92027xz; Aug 24, 2012 at 06:26 PM. Reason: part numbers for belts tried input
Old Aug 24, 2012 | 06:28 PM
94EG8's Avatar
Seagull Management
Default Re: D15B swapped, need timing belt part number
How many teeth is the original belt?
Old Aug 24, 2012 | 06:38 PM
zx92027xz's Avatar
The original belt was thrown away bc I'm an idiot. I swapped it originally several weeks ago. I've just been driving it bc I haven't had time to work on it.
Old Aug 25, 2012 | 03:49 AM
HondaPartsHero's Avatar
Technical Hero
http://civic-eg.com/viewtopic.php?p=173107
Old Aug 25, 2012 | 04:02 PM
tekfoc's Avatar
stock 96-2000 jdm 15B non vtec and probably can use on vtec 15b also ! . part number is 14400-P2A-004 from Honda .
VegaS10
May 20, 2013 12:05 PM
slide inside
Oct 22, 2009 09:25 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
huge230
Oct 4, 2005 12:31 PM
johnzm
Jun 16, 2002 06:56 PM
