clutch releases right off the floor need some advice !!!
Old Aug 22, 2012 | 03:05 PM
bbrian's Avatar
Default clutch releases right off the floor need some advice !!!
i have a built turbo gsr motor , with competition stage 5 clutch with probably 400 miles on clutch , i noticed it was getting hard to shift then finally one day it wouldnt go into gear , checked slave cylinder chnaged it to one i had laying around still no good , so i check clutch master cylinder it was leaking from under neath dash , so i chnage it out , goes into gear nice and easy , then drive it today , go to shift gears its kinda hard to shift and when u come to a dead stop the clutch is barely engaging , so basically when u lket out the clutch it grabs right away and its to the point where u cant drive it on the road , any advice or help would be a appreciated thanks
Old Aug 22, 2012 | 03:17 PM
Pinarr's Avatar
Default Re: clutch releases right off the floor need some advice !!!
I am having the same problem on my 5th gen lude I even bought a new clutch to see if that would change my problem
Old Aug 22, 2012 | 03:49 PM
Gsrsi's Avatar
Did you bleed it?
Old Aug 22, 2012 | 04:21 PM
bbrian's Avatar
yea i bleed the clutch , imma try it again just to make sure and buy a brand new slave cylinder , i noticed that were the shift fork is its making a lil squeaking noise also but , if i go out and drive it in like 3rd gear the clutch doesnt slip or anything
Old Aug 22, 2012 | 04:46 PM
guess_who's Avatar
Did you bench bleed it when you installed the new master cylinder?
Old Aug 22, 2012 | 05:40 PM
TOO MUCH TORQUE's Avatar
adjust the slave cylinder push rod and bleed the lines.
Old Aug 23, 2012 | 08:39 AM
bbrian's Avatar
Kk thAnks I'll try when I get home !!!
Old Aug 26, 2012 | 05:32 PM
bbrian's Avatar
tryed re-bleeding the line still the clutch releases directly off the floor , not even a 1/4 of a inch off floor it moves , bump!!
Old Aug 26, 2012 | 07:46 PM
B20ztek's Avatar
well for starters a Competition Stage 5 Clutch is meant for Track use ONLY. So it engaging a 1/4" off the floor would be a good thing. In a street car, a bad thing..hence why you probably shouldve stuck with a stage 2 or 3
Old Aug 27, 2012 | 12:09 AM
Dioxine's Avatar
Did you Google how to adjust it. Cause if you did you would have found a diagram explaining that is adjusts the same as the BB/MC.
Posted from Honda-tech.com App for Android
bhergh
Feb 11, 2014 05:28 AM
CaliforniaDad
Nov 4, 2010 05:15 PM
jentee
Jun 15, 2008 09:21 PM
allmotorls95
Feb 26, 2003 02:44 PM
allmotorls95
Feb 26, 2003 01:30 PM
