98 civic lx car stalls after cable jump need help please!
here is my problem. i have a new alternator installed and a new dizzy , new spark plugs, new battery. the car doesnt start on its own it needs a jump from my other car. after the car runs i take off the jumper cables, the car runs normal probably for about 2 mins sometimes 3 minutes.. then the car starts to lowering idle until it starts stalling and completley shuts off.. i checked my #15 fuse under my dash it had a 7.5 fuse in it i put a 20 fuse. still didnt fix the problem.but when the car is running if i put it to reverse it just dies on me you can see the lights dimming and it shuts off.. and also tach the rpm on dash just goes all the way down and if i press on the gas the rpm doesnt go up it just feels like the cluster shuts off.. i need help asap need to get the car running.. like i said everything is new. i checked the ground wires from trans to chassis and from head to rad support. and this is not a vtec
just a note the car does have an alarm on it
vtec4max
11
Jun 9, 2011 01:22 PM
jumpmann23
11
Mar 8, 2004 09:23 PM
