Gsr piston ring gap???
Old Aug 20, 2012 | 08:34 PM
B-series BEAST's Avatar
Default Gsr piston ring gap???
I got a b18c1 that I'm building with all oem stock parts I need to know what gap I need for the 1st and 2nd rings...this is ganna be my daily driver and possibly turbo it 8psi in about a year!
Old Aug 21, 2012 | 05:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: Gsr piston ring gap???
May find what you need here... https://honda-tech.com/forums/forced-induction-16/my-b18c1-engine-build-assembly-2951496/ 94
Old Aug 21, 2012 | 02:38 PM
LSVTEC408's Avatar
You dont have to gap/file oem rings. YOu can check the clearances with a feeler gauge but they will be all within specs. If you buy forged pistons with aftermarket rins. Ring gapping is a must. I build motors all day just FYI.
Old Aug 21, 2012 | 02:52 PM
TheRealTegger's Avatar
From the factory manual...
End gap:
1st ring: .008" - .014"
2nd ring: .016" - .022"
Oil ring: .008" - .020"
Groove to ring clearance:
1st: .0018" - .0028"
2nd: .0016" - .0026"
Be aware that Honda is very precise about the placement of the gap on each ring. If you mean to turbo this thing, you really need to blueprint it. And that means a factory manual so you can get everything dead-on.
Old Aug 23, 2012 | 07:04 AM
Ok thanks fellas!! I appreciate it! Now I can get her together finally!!
Old Aug 23, 2012 | 04:13 PM
1998GsRIntegra's Avatar
Do yourself a big favor and invest in one of these: http://www.google.com/imgres?num=10&...r:27,s:0,i:163
manuel19911
Engine Machining & Assembly
12
Nov 24, 2018 07:14 AM
jetpilot
10
Apr 28, 2005 09:22 PM
B pwr
Jun 3, 2003 06:57 AM
Thats-so-Ls
May 30, 2003 12:53 AM
itsalan
May 17, 2003 02:22 AM
