help finding fittings for my oil sending unit
hi i been looking for a fitting to go from my block to conntect a oil line so i can run it to my sending unit. if theres a kit some where can someone post a link? i have a gsr b18c1 with a auto meter oil pressure gauge/sending unit.
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
does the fitting look like 1/8 pipe thread? it's probably 1/8 BSP Honda uses that a lot if it's female threads in the block you need a 1/8 bsp male to 1/8 NPT female, You can get these at a lot of industrial supply places such as MSC the aftermarket gauge and fittings will all be NPT threads
which fitting are we talking about? and what year etc is this? if it's where the original sender screwed into the engine I can almost guarantee it's 1/8 BSP, nearly every Honda uses this for the oil pressure warning sender
This should be what you need, if you are changing the factory warning light sender to a gauge, this cahnges the BSP threads in the block to NPT which is pretty much standard for all aftermarket gauges
https://www.pegasusautoracing.com/pr...asp?RecID=3142
integra-modder
Jul 7, 2004 08:19 AM
beemaz
Mar 8, 2004 06:24 PM
