WTB: EK manual trans conversion parts
Looking for:
- d-series flywheel, clutch disc, pressure plate and flywheel bolts
- upper trans bracket (not mount) 50825-S04-000
- lower trans mount and bolts
- rear trans mount (and possibly bracket? I believe the auto bracket can be used) 50810-SR3-030
- manual pedal assembly
- manual EX (if you have matching injectors, intake manifold that's a plus) or DX ecu
- d-series shifter linkage, shifter, shift **** and boot
- clutch master and slave cylinder, hard and soft lines
- d-series hydro manual trans (doesn't matter CX, HX, DX, EX, etc), starter and vehicle speed sensor
I'd prefer a local sale if possible, with most of the parts coming from the same car. Located in NE PA 18017
- d-series clutch disc, pressure plate ---- I have these for a y7. Unknow mileage, but still looks in good shape
- manual pedal assembly - I've got a full set of pedals from a 00 Si...
- d-series shifter shifter, shift **** and boot----- I've got a skunk2 straight shaft SS, skunk2 weight **** and the 5spd shifter console with what looks like an aftermarket boot
- clutch master cylinder ----- I have one of a 00 Si... not sure if they are different for the B/D series or not. I also have D-series hardlines that run from the clutch resevoir, along the firewall, all the way to the slave (not sure I still have the slave... will have to check)
Throw me an offer on all that and we can start there. I am willing to ship as well.... out of Cincinnati/Dayton.
Text or email is fastest:
513-253-6660
whiteacclude@yahoo.com
Check my sigs too... lost of parts in there and additional parts from a 00 Si that I've not yet listed.
513-253-6660
byronl
44
Apr 11, 2006 03:53 PM
idriveadelsol7
Mar 23, 2005 02:21 AM
