pls help me identify this parts name.
Old Aug 19, 2012 | 04:25 PM
kekorangar's Avatar
Icon2 pls help me identify this parts name.
please help me identify the name of this part from my 1994 honda civic LX 4 door sedan. it is a 1.5L 4 cylinder 16 valve engine with a carburetor (ph15 philippine made). thank you.
this part is located under the carb
i think this part affects the idle of my car. the idle is erratic i think due to the damage to the said part seen in the last 2 images. a link to a supplier of said part would also be greatly appreciated. thank you.
Old Aug 19, 2012 | 05:34 PM
EsotericImage's Avatar
Retired Moderator
Default Re: pls help me identify this parts name.
looks like a vac manifold... and yea, it will effect idle and performance
edit: my hypothesis... im not familiar with carb'd hondas
Old Aug 19, 2012 | 06:24 PM
upnsmoke's Avatar
It has six legs, so it's definitely an insect of some sort. j/k. Yup, it's a vacuum manifold. There are some aluminum ones available, but they are a bit pricey. link I would think someone would sell a cheap plastic or brass replacement, but I have not bought one recently enough to remember. Worst case, you could use a few plastic t's, or do like me and make your own from plumbing stuff.
Old Aug 19, 2012 | 10:19 PM
kekorangar's Avatar
thanks for the replies guys. any idea on how to install the aluminum replacement? if you noticed on my original part, one hose port is on top while the other 5 is on the side, while on the replacement aluminum part, all ports are lined up on the same side. thanks again
Old Aug 19, 2012 | 10:27 PM
jbpnoman's Avatar
They're just vacuum lines - the orientation doesn't matter.
Can you post the engine code for us? I'm curious.
Old Aug 19, 2012 | 10:34 PM
kekorangar's Avatar
thanks . as for the engine code, im pretty sure it starts with PH (from/made in the philippines), cant check atm since im at work.
Old Aug 20, 2012 | 03:13 AM
kekorangar's Avatar
are we all unanimous that said part in question is indeed called the vacuum manifold?
it just seems funny to me that i cant find another actual pic of said part on the internet.
this part is supposedly oem, and even in honda engine/carb diagrams, i cant seem to find it.
thanks all
Old Aug 20, 2012 | 07:47 AM
HondaPartsHero's Avatar
Technical Hero
This is for a 87 Civic but for reference they call it a 9 way joint
http://www.hondapartsunlimited.com/f...BING%20%281%29
Old Aug 21, 2012 | 06:27 AM
kekorangar's Avatar
guys, i need confirmation if this part's name could be the "PORTED VACUUM SWITCH"?
if it indeed is a ported vacuum switch, my problem now is to find said part with 6 ports maximum ports i could find is 5 ports
thanks
Joe_the_diy_guy
Engine Machining & Assembly
Oct 22, 2016 10:04 AM
bosted429whp
Apr 4, 2012 05:47 PM
allmotorek8
Jun 2, 2009 05:33 AM
jakeiscool
May 27, 2006 11:57 AM
