Driver side window wont work
Old Aug 19, 2012 | 09:44 AM
leeto206's Avatar
Default Driver side window wont work
hello everyone, im posting to see if someone can help me out with my window.
so, everyone of my windows but the driver side works. i checked the fuses, the power window relay and nothing, i checked all the wires going to the window motor and there is no electricity going through them, any suggestions???
i feel like its the motor but theres no electricity going through it and the relays and fuses are fine and at the right amperage
car is a swapped 1992 civic 4 door
Old Aug 19, 2012 | 11:25 AM
shiroitenshi's Avatar
Default Re: Driver side window wont work
check the switch at the door panel, occasionally crud and stuff get in and the switch doesn't engage properly.
motor, you can clip on a 12v battery on the motor terminals and see if it works.
Old Aug 19, 2012 | 01:59 PM
1low93's Avatar
I have the same issue with a 93 integra but my motor allows the window to go down but wont let it go up... im looking to replace the motor but not sure where to start looking. I tried AutoZone, And Oreillys they want $100+. Any one with a used motor or ideas??
Old Aug 19, 2012 | 03:38 PM
turbohatch96y7's Avatar
If your motor goes up and not down then the motor is fine.
Its most likely the window switch. Start there.
You'll need a multi meter.
Old Aug 19, 2012 | 03:46 PM
1low93's Avatar
The switch has been replaced. it still does the same thing.
Old Aug 19, 2012 | 03:47 PM
1low93's Avatar
Is there a way to test the wires for power going to the motor in both directions?
GsRrrr
Jun 14, 2011 04:02 PM
si_motor_spt
Honda Civic (2001 - 2005)
14
Jul 12, 2010 01:37 PM
da_ska
May 31, 2009 02:32 AM
bLaCkNbLueLuDe
Apr 28, 2009 04:40 PM
Edgemingsr
Jun 2, 2004 10:08 PM
