Ls integra soon to be type r swapped need some advice
I am going to be performing a type r swap on my 99 LS integra and need some advice/ help. I have a very strong mechanical and electrical back ground. I am a former BMW master tech so the swap it's self is no issue my questions are wire harness related. 1) does anyone know what wires will need to be added to the vehicle I will be using the harness that's supplied with the engine. And two) will the type r header bolt up to my existing cat? And are there any other figment issues or any engine/ transmission issues that should be looked at or replaced before its in the car
Thanks a bunch
Thanks a bunch
You will have to wire in a vtec wire for sure, I'm not sure if ur R motor has a knock sensor but that would have to be wired too, also the cat fitment will depend on what type of header u have... I have a cdm type r and I believe the cat on cdm/usdm type r's is shorter in length than Jdm type r cats which affect header/cat fitment, also jdm headers have a2.5" colector and usdm r headers are 2.25 like which is what ur ls cat should be. that's all I can think of off the top of my head
What year is the motor? Is it usdm or jdm or what (mainly a concern because a rhd harness cannot be used in a lhd car)?
Yes, vtec, knock sensor (depending on the ecu you're wanting to use). Should be it... in your situation.
Just off the top of my head, you need to know the following:
The OBD version of the engine(ex. OBD2A, OBD2B)
What ecu? JDM ecu or USDM? (chipped p28/p06/etc. OBD1, USDM Type R, JDM Type R)
Keep in mind that the car will not pass emissions on a chipped OBD1, or JDM ecu. The USDM ecu will have an immobilizer that would need to be removed.
If you decide to go with the 97-98 USDM Type R ecu or JDM Type R ecu you won't need a jumper harness. Both of the ecu's are OBD2A, same as your 99 LS Integra.
I suggest doing research....
jdm spec 96-98 will more then likely be the engine but might have to get 98+ all depending on what the guy has in stock when i go out to pick it up. and as far as the added wires this would do the trick correct?
http://www.rywire.com/catalog/obd1-o...ness-p-18.html
thanks all for the help it is greatly appreciated.
you will have to run 3 wires, vtec solenoid wire, vtec oil pressure switch, and knock sensor wire. Use shielded wiring for the knock sensor or your car will get check engine and probably pull timing like mine did. To pin in the wires go cut the ecu harness out of a civic or another integra and pull the ecu pins out from the back of the connector. Then you can just slide them into the back of the connector of your ls harness, there will be open spots on the connector for the pins. If this doesnt make sense just ask ill walk you through it, ive done a few honda swaps including k20 so can probably answer any questions you got.
-max
-max
Yes, that will take care of the extra wiring vtec and knock etc. However, if you want to pass emissions you will need a USDM ecu (P73-a02, P73-a03, both being OBD2A and not requiring a jumper harness) The downside to running one of these ecu's is you will need to perform this http://ff-squad.com/wp/?p=309 or replace the JDM oil pump with a new USDM OBD2 style oil pump and use the CKF sensor from your old engine. This will allow you to be cel free and pass emissions.
If you do not care for emissions, grab a P28 ecu and have it chipped with one of several available programs/software. This will bypass knock sensor etc, along with the dreaded Crank Fluctuation Sensor which will not be present on your JDM engine but there are provisions for it in your 99 LS wiring harness.
Might want to look into that....and figure out exactly what you are wanting to do.
FWIW, 99 integra LS already has knock. You should only need to add the vtec wiring.
The jdm header has a 2.5" outlet and is significantly better than the us one. You will need to weld the larger flange onto your cat to make it work though.
B-series axles are all the same (26 spline), with the exception of the jdm itr which are 27 spline. Problem is that you will have to swap to the jdm itr or crv spindles (and associated 5 lug) to make them work. Your LS axles will be fine. Look up the ffsquad page referenced above for the way around the ckf sensor.
If you want to save money, manually wire vtec. 1 pin from ecu to solenoid (A8). JDM engines typically have no pressure switch.
This won't be needed if running the JDM ecu that comes with the engine.
The sub-harness comes with vtec, knock etc. If he wanted to go the sub-harness route then it would come with knock sensor already, you do not have to use it or Intake Air Bypass.
again thanks guys i am going to try to pull this off in one day. remove engine and swap in new one in an afternoon i am going to replaced the clutch the timing belt and water pump and plug wires and plugs. all drive belts and have engine and trans reassembled waiting for a three day weekend to do it in case i run out of time. hopefully with enough beer supplied by me some buddys will show up and help. lol again couldnt thank you enough for the advice.
Luckily, instructions for the sub-harness are located on their site here
http://www.ff-squad.com/technet/wiring.obd2a.htm
Here you go this makes things even easier tells you exactly where to wire in to ecu. good luck!
hey check this out i have a 1995 jdm b18c r and im swaping it into my 96 ls . i noticed that my ls wiring harness has a extra sensor plug for the ckf crank shaft speed fluctuation sensor i already know im going to need to use my oil pump cover on my type r engine but will i need to also replace all my other sensors and is the ckf sensor nesecarry to have on my engine will it show check engine light with out it and is my 96 ls engine harness sutiable to use on my b18cr
Peter K
Jul 6, 2001 12:14 PM
