check list before taking my car to be tuned?
ive been installing my turbo parts over the last week while ive had time and will be setting up a tune date more than likely on wed (8/22).
things ive done/checked:
install manifold
turbo
wastegate
dt and dp and exhaust
drain
feed
fuel pump
changed oil
wideband
intercooler
MBC with vacuum lines ran
still have to install:
MAP sensor
injectors
Change spark plugs
install intercooler piping (waiting for it to come back from my welder)
install vacuum line to boost gauge
oil press guage
i checked for leaks and there are none from the feed line or drain. anything else i might be missing or over looked?
install manifold
turbo
wastegate
drain
feed
fuel pump
changed oil
wideband
intercooler
MAP sensor
injectors
Change spark plugs
oil press guage
It really, realLY, REALLY helps to actually search. First link on the Google -
http://www.kingmotorsports.com/c-177...checklist.aspx
...one of MANY.
You can't install the injectors or a higher reading MAP sensor without setting up the EMS for it first.
...one of MANY.
forgot to say s300 is already installed in a p28. and thanks for the link. ill check it out.
edit:checked the link out. seems like i have everything done so im good to go.
thanks
thanks
make sure you have the gasket ring installed on the wastegate. i made the mistake and didnt install it, so the tuner had me install it when he noticed i didnt have it in, lol!
Do you mean that metal fire gasket/ring that goes on the manifold side? Yeah I have that in there. But almost didn't until I noticed it sitting in the box
For me I didn't know what to do with it
Synapse engineering instructions suck, so I brought it with me to the tuner
i skimmed through the stickies/faqs at the top. didnt see what i was looking for. didnt think about checking evan's site. thanks guys.
