92 honda accord lx passenger - Passenger window won't roll down after..
1992 Honda accord lx. ,, removed door panels off, to install new speakers, have not installed new speakers yet, but have left door as is for the day, now its night and need to roll up windows, and attach panel to driver side window and plug in just the window switch .. turn key to acc - roll up driver window. unplug panel from door... go to passenger side , same process, only hook up window switch.. turn key to acc.. nothing, no up no down, tried with car on.. tried other door panel.. ( to see if other door panel would be able to roll it up from the drivers side ) - nothin... started car.. nothing...what could it be? and how do I troubleshoot? or even just get the window up without causing more damage??? - thank you
Are you doing this with both switches plugged in?
Anyway, you can always put 12v to the motor. I forget which wire to + to make it go up. Try it one way, if that doesn't work switch the wires.
yep that was it.. tried plugging in both doors at once.. bammo.. window cranked right up... now if i could just wave a wand and my rear trans mount would install itself id have it made! but finding an easy walkthrough on how to do it is like pullling teeth!
Never done the rear mount on a 4th gen, so just a theory here......did this on one of my 3rd's gen not long ago.
Of course the car and engine have to be supported with proper safety!!!!! If you try to remove the "bracket" from the back of the engine/trans and then the mount?????? Worked on one of my 3rd gen rear mounts.......again, different cars but something to think about. Don't get me wrong, getting the bracket off the block took some long extensions and that.
aresjay
Oct 17, 2018 01:36 PM
pre90
Jun 9, 2015 10:22 AM
chris4x4
13
May 8, 2011 10:39 AM
