bouncing speedometer among other things
i know there are a million threads covering the tsb about connector c115
my car does not blow the 7.5 fuse in fuse 15. the speedometer bounces under heavy acceleration the lights dim and the idle seems off. the car is a 1999 civic ex with a b18c-r if that helps any thanks
Ohm and short test the large white alternator wire between the alternator and hood fuse box.
Clean and tighten the battery ground wire that connects to the chassis.
Yoitshector
45
Aug 25, 2012 08:27 AM
Str8JDMCRX
Oct 26, 2010 02:17 PM
