Transmission clicking while clutch pedal not being pressed.. with video
So I'm having an issue with clicking while clutch pedal is not being pressed. Noise is heard in low rpm's in idle as well as in gear, and increases in loudness depending on how slow I climb thru the rpm's. You may also hear that I have an exhaust leak, need to go pick up a doughnut gasket tomorrow! Any help with diagnosing the issue would be GREATLY appreciated!
Quick drive to 30mph you can hear the clicking in 3rd.
http://youtu.be/S6ITGFF72dQ
Another short drive through a few gears, you can hear it better in this one as I was driving slower. You can also briefly hear it come in between 1st and 2nd, and much louder in 3rd.
http://youtu.be/qPOdGVFRKgI
Idling you can hear the noise lightly while clutch is not being pressed, and while pressed it disappears. Also can hear it on a few light revs
http://youtu.be/NK3Zyar-Msc
ISB. Order the mainshaft bearing and seal underneath it. It will be the bearing w/seal on the clutch housing diagram at the Honda dealer.
i have the exact same problem and theres a lil leakage under the tranny when the cars turned on. plus theres some black watery **** coming out from my exhaust pipe. does anyone know about this or know how to fix this problem?
DeeJaaY209
14
Sep 15, 2013 10:40 PM
93delslow315
May 7, 2011 09:59 AM
levifps
Jun 25, 2007 12:16 AM
